Test Image up-load via Imgur by seawings
Read this locked posting to find out the easiest way to up-load photo's with your text postings.
Postby seawings » Sat Apr 21, 2018 7:51 am
Ok, let's see if this works.......
https://imgur.com/umPJK2q
Re: Test Image up-load via Imgur by seawings
Postby seawings » Sat Apr 21, 2018 7:53 am
Hmmm, not quite, try again.....
https://i.imgur.com/umPJK2q.jpg
Postby seawings » Sat Apr 21, 2018 7:54 am
Number 2 is better as it takes one straight to the actual image BUT I want the image on the forum page, so try again....
Postby seawings » Sat Apr 21, 2018 8:06 am
BINGO..!
Ok, this is the result of using:
Photo Host: IMGUR (Easy to sign up, easy to login and very easy to use, once you've figured out which display option to use!
The method I used is 'drag & drop' the image onto the Imgur Upload page, it automatically displays in-front of you and then automatically uploads the image, simple.
Then, when the image appears in you hosting page you have created by signing up to the site, look to the right-hand side of the page and you will see a list of options for links to do what you want for that image. Next to each link is an icon entitled 'Copy'. For the forum purposes, click the copy icon next to the link headed 'BBCode (message boards & forums)' and copy that link into your forum past.
When you complete your forum post and submit it, your image will be displayed just like mine above.
Simple.
Enjoy!
Return to How To Up-Load Photographs To This Forum.
