Short Singapore
This section is specifically for the budding profile artists amongst you to share your latest works - and show the rest of us how it's done!
Short Singapore
Postby JMSmith » Sat Oct 24, 2009 6:54 pm
i will start it again then Bryan,
first bit, 2 layers, original drawing layer one, black silhoette layer 2
when this is correct i will make a mask of it
JMSmith
Re: Short Singapore
Postby JMSmith » Sun Oct 25, 2009 10:29 am
hi all,
thanks to Roy i have now got the correct shape and have made a mask.
this is the shape the mask is made from, now it's playtime.
JMSmith
Re: Short Singapore
Postby JMSmith » Sun Oct 25, 2009 12:07 pm
and now the fun starts,
i have a drawing from the manual and that is slightly different, so it back to the good old fashioned checking photos against drawings :(
you sure you want to start drawing bryan :twisted:
JMSmith
Re: Short Singapore
Postby TASSE » Sun Oct 25, 2009 3:49 pm
Yes, even manufacturers drawings can often differ with the final thing as many times the aircraft can be altered on the workshop floor. I have found many examples of this when doing scale drawings.
Re: Short Singapore
Postby JMSmith » Tue Oct 27, 2009 9:45 pm
here we go, six layers allhighlight to start the basic forming.
JMSmith
Re: Short Singapore
Postby JMSmith » Sat Nov 07, 2009 11:48 am
moved on a lot,
more shading cockpit fitted and those bloody portholes, the porthole drawing was 27 layers, done 4 time larger then all layers merged then resized and copy pasted onto fuselage, two different type portholes, lefthand and righthand :o
JMSmith
Re: Short Singapore
Postby JMSmith » Mon Nov 16, 2009 8:43 pm
hi guys,
a little more :P
JMSmith
Re: Short Singapore
Postby TASSE » Sat Nov 21, 2009 2:38 am
John, check the kink in the leading edge.
Re: Short Singapore
Postby JMSmith » Sat Nov 21, 2009 6:38 am
hi roy,
the kink is formed by the fuselage to main wing curving up, then going staight for about a foot then the wing go in normal diahedrel, looks realy good in some photos
JMSmith
Re: Short Singapore
Postby JMSmith » Sun Dec 06, 2009 1:01 pm
still at it,
JMSmith
Return to Artist Profiles of Flying Boats and Seaplanes
