Thulin with 3 engines.
Postby TASSE » Sat Jul 18, 2009 1:02 am
I hope that someone can show some photos of this Swedish 3 engined Thulin H.
Re: Thulin with 3 engines.
Postby AquilaAudax » Sun Jul 19, 2009 10:23 am
Hi Tasse
If you go to http://www.landskronakultur.se/flyghistoriayou will find a swag of images of the Thulin 'H'.
I have some high-res scans of some of the better views if you need higher quality images.
Interestingly it was the only trimotor floatplane powered by three rotary engines (obviously Thulin's own !).
Cheers, AA
AquilaAudax
Postby TASSE » Sun Jul 19, 2009 3:22 pm
Thank you AA. I had a feeling that you would come to the rescue.
Such good photos but none of it in flight.
Cheers. TASSE.
Postby AquilaAudax » Fri Jul 24, 2009 9:33 am
Hi Tasse
There are probably few, if any, photos of it in flight as it had major problems getting into the air. It managed a maiden flight off sea water but couldn't repeat the exercise off a fresh water lake. Most sources erroneously state that it had its first flight some time later with a wheeled undercarriage off a frozen lake - there is a photo of it being prepared for that flight. Interestingly it was displayed at the Skandinaviska Flygutställningen in May of 1918 (at Kristiania - now Oslo) with both a wheeled undercarriage and floats - a bit of two bob each way !
Cheers, AA
AquilaAudax
Return to Float Planes and Seaplanes ONLY - Early Days to the end of WWI
