Floats
Floats
Postby TASSE » Fri Apr 17, 2009 12:10 pm
The first product by Grumman was an amphibious float seen here fitted to a Vought O2U-4 Corsair.
(Bet you did'nt know a Corsair looked like that).Image
Re: Floats
Postby TASSE » Fri Apr 17, 2009 12:17 pm
And here is Vought O3U-1 Corsair fitted with a Brewster float. Note the arrester hook.Image
Cheers (more to come) TASSE.
Re: Floats
Postby JMSmith » Fri Apr 17, 2009 6:18 pm
nice images roy,
i knew you would get the hang of it, keep em coming
JMSmith
Re: Floats
Postby TASSE » Fri Apr 17, 2009 10:56 pm
A pair of Edo floats used as a drilling rig in Australia.Image
Cheers TASSE.
Re: Floats
Postby TASSE » Sat Apr 18, 2009 10:34 pm
Various Westland Wapiti's were fitted with floats such as this one photographed at Calshot. The Royal Australian Airforce also had some.Image
This one is equipped with Short built floats
Re: Floats
Postby TASSE » Sun Apr 19, 2009 7:08 pm
Here is a drawing of the suspension on a wooden float for a Short 184.
And also of the float structure.
More drawings to come. Watch this space. TASSE
Re: Floats
Postby TASSE » Fri Apr 24, 2009 8:38 pm
A photo of an Avro 504'O on wooden floats. Note the wing-nut attachments.
The 504'O was a float version of the 504'N with an extended fin.
My drawing of a couple of American floats.
Re: Floats
Postby TASSE » Fri Apr 24, 2009 8:42 pm
Well i dont know what happened there. I will try again.
Re: Floats
Postby TASSE » Fri Apr 24, 2009 8:45 pm
Sorry. The bottom of that one got chopped.
Re: Floats
Postby TASSE » Thu Apr 30, 2009 7:38 pm
The retractable undercariage on the Short Gurnard II (N229). Compare this with the Grumman float of the same period.
