Three engines
Three engines
Postby TASSE » Thu May 21, 2009 9:39 pm
Here is something for the Ford fans.
Ford 5AT - Ds. (NC.9657).
RCAF.
Columbian Air Force.
Re: Three engines
Postby MrWidgeon » Fri May 22, 2009 10:51 am
Did someone mention Fords ?
Here's WZ before it put on mufti.
And after.
And a couple more civilians.
And just for good measure a single engine Ford Model 8AT (with a single 700hp Wright Cyclone up front).
Re: Three engines
Postby TASSE » Sat May 23, 2009 1:02 am
CF-BEP was the last float plane used by Grant McConachie who eventually formed Canadian Pacific Airlines.
His biography is written by Ronald Keith. Bush Pilot with a Briefcase is certainly a worthwhile read. it was re-published two years ago.
Re: Three engines
Postby TASSE » Sun Jun 21, 2009 8:49 pm
Here is a couple more.
