What is a Duck - a floatplane or a "flyingboat"?
Postby Rajay » Fri Aug 08, 2014 6:25 pm
I personally think a case could be made either way - just curious to hear what everyone else thinks...
Floatplane (Curtiss Seagull):
Flyingboat (Republic Seabee):
What? Something in-between (Grumman Duck):
Re: What is a Duck - a floatplane or a "flyingboat"?
Postby WhyMe » Fri Aug 08, 2014 6:33 pm
IMHO even though it's a single hull, the separate "fuselage" and "float" are clearly defined, hence it's a floatplane :roll:
Here's a more interesting case: Great Lakes XSG
Is it a floatplane with a tail on the float? Or is it a flying boat with a cockpit inside the engine nacelle? :mrgreen:
WhyMe
Postby MrWidgeon » Sat Aug 09, 2014 1:55 am
The Duck is (was ?) a flying boat.
It cannot be operated without the lower hull section, nor was it ever intended to be operated in that manner.
The separate hull and fuselage sections were done strictly for manufacturing reasons.
Postby MrWidgeon » Sat Aug 09, 2014 1:58 am
The same thing applies regarding the Great Lakes XSG.
It cannot be operated as a landplane, hence it's a flying boat.
Postby WhyMe » Tue Aug 12, 2014 8:33 pm
Thanks for the explanation, MrWidgeon.
As far as I understand your logic, if an aircraft can be operated without floats then it's a floatplane, otherwise a flying boat.
I'm not trying to argue, but here's another interesting case: Shavrov Sh-5.
Clearly a flying boat, isn't it? Yet it can be operated without floats and the lower part of the "boat" hull:
Does it make it a floatplane then? :?
WhyMe
Postby MrWidgeon » Thu Aug 14, 2014 9:13 am
I was afraid someone would bring that one up.
I don't know how to classify that thing other than to say it was originally built as an amphibious flying boat with a removable hull.
It could be operated as a landplane and was tested as such until it broke a landing gear strut and the project was abandoned.
Return to Grumman J2F Duck Reference Archive
