Short Sunderland Mk III Forward turret
Information requests specifically on flying boat guns, gun turrets, depth charges and rockets. This is the place to post photos, plans and documents to form an historical archive.
Postby sunderlandmr5 » Fri Feb 25, 2011 11:05 am
Hi all
Looking for some help please, does anyone have any photos or drawings of the
forward turret for a MK III Sunderland.
Note the Mk III turret differed to the Mk I/II and changed again from the
Mk IIIa to MkV
Ideally a side shot and forward shot if possible please?
Thanks in advance
Re: Short Sunderland Mk III Forward turret
Postby sunderlandnut » Fri Feb 25, 2011 11:24 pm
This is from ‘Sunderland at War’ by Chaz Bowyer
Postby sunderlandnut » Sat Feb 26, 2011 12:07 am
Is this any help?
From ‘Maritime is Number Ten’ by K C Baff.
Postby dogsbody » Sat Feb 26, 2011 12:11 am
There's not much out there showing a Sunderland nose turret, is there. I have a few good shots of the tail turret, but nothing on the nose.
Postby sunderlandmr5 » Sun Feb 27, 2011 5:43 am
Hi Tony/Richard/Chris
Thanks for your replies
The photos and drawing certainly are a big help-thank you
I will have to, I think vacform some new turrets
for the Mk III I'm building, as the kit ones are worthless,
and aftermarket ones don't appear to be correct.
Thanks/regards
Postby seawings » Sun Feb 27, 2011 10:50 am
Is it the single gun turret or the twin gun turret you want the details on?
Postby sunderlandmr5 » Sun Feb 27, 2011 11:56 am
seawings wrote:Is it the single gun turret or the twin gun turret you want the details on?
Hi Bryan
It's the Twin gun turret I'm after.
The Mk III (not Mk IIIa) was the first as far as I know,
to have the twin gun forward turret.
Trying to get a decent photo or drawings has been a mission
Postby seawings » Sun Feb 27, 2011 4:09 pm
This has come into me from a Sunderland afficianardo:
The Mark III still retained the single Vickers 'K' ..303 as per the earlier versions. However the Mark IIIA had twin belt fed Browning .303s + 4 fixed .303s in the bow. As far as I have been able to find out, the glazing on the front turret only had the glazing altered. Easy way to tell the difference at a distance between both is that the IIIA had twin radar scanners under the wings
Any help?
Postby seawings » Sun Feb 27, 2011 7:29 pm
More: Original nose turret fitted and as used on the II. The twin Browning version for the IIIA and V was the Frazer-Nash FN-5
Postby sunderlandmr5 » Mon Feb 28, 2011 10:34 am
Hi Bryan
Thanks for your reply
The following things I have found
In a commentary written by a Sunderland pilot who flew Mk III's
during WWII (Mac is his name) he stated that (at least in
the West African Mk III's) that the following applied on Sunderlands he
flew in
1) Mk III's flew with a single VGO (Vickers Gas Operated) MG (.303 cal)
this was in liu of the twin Brownings usually carried, as the Lufwaffe
was not a threat in that area
(this begs the question when did the Mk III carry twin brownings prior to the Mk IIIa)
This is a 490 Sqn Mk III West Africa
(Photo used for illustration only)
2) Mk III's did not carry the upper mid turret
3) Only Sunderlands based in the UK carried the bow mounted x4 Brownings.
Mac's Mk III (DW109/Q) had the MkII ASV equipment (Yagi aerials etc) so was
not a Mk IIIa
Unfortunately the only photo I have of DW109/Q is at a distance, so the
forward turret is not that clear
Pehaps I may have to go with either a Vacform similar to the photo above or Falcon models sells
the set
Thanks for the replies
Return to Flying Boat Weapons
